Best Sound Card
Discussion in 'Computer Components' started by Ken, Dec 28, 2001.
  1. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    Can anyone advise on the best sound card to replace a SB Live 5.1
    Ken
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Either the MAudio Audiophile 2496 (no analogue multi-channel output) or the new Hurcules Gamer card (with 6.1 output now) would be suitable to replace your SB 5.1. They are both around the £150-200 mark.
  3. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    Has anyone got any links to cheap suppliers of the M Audio Audiophile 2496?
    UK or anywhere in Europe.
    I want one, just got to find a cheap supplier now.
    Mark G.
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    The best place to find suppliers of the 2496 card is in Sound On Sound magasine. There are loads of adverts that have it in. I think they have a website (who doesn't?), dunno the address though.
    Here it is: http://www.sospubs.co.uk/
  5. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    Thanks for the reply Richard.
    How does the M Audio compare to the Terratec, as it can be purchased for £20 less.
    Ken
  6. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +548
    Jeff (builder of Kryton) has one of these but has often mentioned that he has problems with Ravisent based dvd software. The M-Audio is by far the most often used on http://www.avsforum.com and that means that they will have already come accross (and probably solved) any problems that you may have.
    Good luck
    Alex
  7. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
