Ari33
Established Member
Hi all..
I'm using a TEAC A-R600 stereo amp to drive two 4 ohm shaker/transducers on a racing sim rig that I'm building for my son.
It puts out 150w per channel and is rated to drive 4-16ohm speakers. It works very well and produces an ideal amount of vibration feedback around the 50-60% volume mark but overheats and temp protection mode kicks in after about 10 mins of use. It does have a small slow moving fan inside but it is clearly not adequate for this load.
I merely turn down the treble to min and increase bass to Max at the moment but have a (line level) cut off/crossover control unit on its way from BG.
My questions are..
Will setting the cut off to 60 hz on the crossover help make the transducers easier to drive and thus reduce heat... or...
Do I really need to add some 12v PC type fans to help dissipate the heat... and if so... will I likely be able to find a decent 12v DC voltage source inside the amp that I can tap into for the fans?
Any insight on the best approach to deal with this would be much appreciated..
TIA..
My questions are..
TIA..
