Best software to test CRT?
Discussion in 'General TV Discussions Forum' started by kebabek, Jun 9, 2005.
  1. kebabek
    kebabek
    Mar 6, 2005
    22
    Hello!
    I decided to buy 36" CRT TV and I read a lot about geometry problems of these big CRTs, that is why I was wondering, which software is the best to test the screen before buying it.
    Is there any kind of software available to download from internet?
    Thx
  2. JayCee
    JayCee
    Jan 20, 2004
    22,184
    Lanarkshire
    +2,307
    How can you test it before buying it?
    On forums like these you only see posts from people with problems.......you rarely see posts from satisfied owners.
    If you buy a good well-known brand such as Panasonic, Sony, Toshiba you will find the geometry perfectly acceptable.
    Ask to see the set switched to Teletext and examine the sides, top and bottom of the pic.......that will give you a idea of geometry setup.
  3. GaryB
    GaryB
    Nov 12, 2002
    5,386
    St Albans
    +1,292
    If you have access to a PC with a video output I have a monitor test program that can generate lots of test patterns. PM me your email address and I'll send it over.
    If you can't do that, then a standard video pattern generator is the best way to check.
  4. Eiji
    Eiji
    Feb 16, 2005
    1,422
    48
    +69
    Hey GaryB,
    I'm interested in this software too.
    Could you send it to my email address? I'll PM you my email address now just incase you don't have it from last time.
    Thanks.
  5. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    You're setting yourself up for a major disappointment.
    The default contrast setting for most CRT TVs will cause some pretty awful geometry issues. This goes as much for 28" sets as it does 36".
    Before testing the geometry you should take the time to set the contrast correctly. While you're at it you might as well set the brightness, sharpness and colour correctly too. The simplest way to do this is with a copy of Digital Video Essentials for PAL. The DVD is about £15 from the usual internet retailers.
  6. Will Scarlet
    Will Scarlet
    Oct 1, 2005
    2,569
    Eastcote
    +645
    Agreed. If you've got a DVD player do as Chris suggests and get DVE, it has all you need to set up your CRT correctly. That and all you need to set up your sound system too!
    My JVC HV-32D40 was a dog out of the box, but after some tweaking with DVE it is now superb. Short of getting an engineer to set it up, I couldn't really ask for more.
  7. GaryB
    GaryB
    Nov 12, 2002
    5,386
    St Albans
    +1,292
    Unfortunately the programs I use for testing are at work and I'm not back there until the 9th of Jan.
    One of the best of them is available as a free download so you can get it direct:
    http://www.monitortest.net/
    Choose "Monitor Test Program".
