Best software for PCs
Discussion in 'Headphones, Earphones & Portable Music' started by Pecker, May 6, 2007.
  1. Pecker
    Pecker
    Dec 26, 2004
    22,494
    Huddersfield, People's Republic of Yorkshire
    +4,612
    I now have a PC linked to a 32" LCD in my kitchen. It's also linked to a very good Denon mini hi-fi unit. Details of how this happened is here:
    http://www.avforums.com/forums/showthread.php?p=4771117#post4771117
    I want to be able to play any of my music on this system. My CD collection is 2 floors up. It's easier to use this PC than to run up and down stairs.
    So, I now have a PC, a display, and an external hard drive big enough to hold all the music I want.
    What's the best software to play and orgainse the music? I currently have Creative MediSource Organiser and Windows Media Player.
    The software should be able to sort my current files so they're accessible easily by track, artist, or album, with easy to make (and easy to play) playlists.
    It should be idiot proof because the missus needs to use it.
    Cheers.
    Steve W
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
  3. Pecker
    Pecker
    Dec 26, 2004
    22,494
    +4,612
  4. Pecker
    Pecker
    Dec 26, 2004
    22,494
    +4,612
    Looks great, is it easy to use?
    Is FLAC the best lossless to use?
    Steve W
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
    Yep, it's quite easy to use once you know your way around!
    I don't use lossless much, but the few tracks I have converted I normally use FLAC. Othr lossless formats include ALAC and WM Lossless. Personally I'd stick with FLAC.
  6. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    J River Media Centre and OrangeCD or both good, as you have the big telly, also Windows Media Centre
    BTW, have you considered running slimserver on the PC with a Squeezebox connected to the Denon? The standard sound card in the PC isn't generally 'hi-fi' in any way...
  7. Pecker
    Pecker
    Dec 26, 2004
    22,494
    +4,612
    I'm a bit hacked off.
    I've downloaded MediaMonkey. I put in a CD and it won't pull any tag information from the internet.
    I've then started the Creative programme again and, if I try using their system (gracenote) that won't work either. I get a little box saying it won't get any info because the info provider's server is down (doubt it), my internet connection is down (as you can see, it isn't), or it's a copy controlled CD (it isn't, indeed I've tried ones I've ripped before and got the info from Gracenote.
    BTW, with FLAC at media monkey, should I set compression to '0' or '8'?
    Steve W
  8. Autopilot
    Autopilot
    Feb 5, 2005
    7,629
    Region 2
    +1,516
    Just leave it at setting 5. At the highest setting you will only notice a very small increase in compression, yet encoding will take a long time.
