Best slimline, cheap amp?
A
alexjascott
I am fairly new to the Home Cinema Scene.
I have bought some Sonare 5.1 speakers (fairly low level NXT speakers). I want a cheapest amp/receiver to go with them, preferably fairly slimline and easy to use. It has to be silver.
I will have my sky+ and my Sony combi going into it, and may want to connect my gamecube. I have a very small room, and hence the need for small/quiet speakers.
It would be nice to have the extra power if I ever decide to upgrade my speakers (the Sonares are 42W peak power; frequency response 52Hz-150Hz ±6dB), but not a necessity.
Would also be nice to have a smallish remote, as the amps one I have seen tend to have lots of buttons on them.
I am a sucker for a bargain.:cool:
There aren't too may slimline av amps around I'm afraid but a few can be found here:-
http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=301576
http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=301713
http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=300401
all offer the sound formats you'll need (DD, DTS and prologic II) with varying wattage and at an affordable price:)
Any of these examples should do a fairly good job of filling a small space with sound. The only way to see which one sounds best to you is to go have a listen.
good hunting:)
I know its not slimline, but what do people think of the Sony Str-de475?
I know someone selling his for £115, and so might compromise on space if I cant find a better solution for reasonable money.
I also noticed that Richer Sounds are doing the Sony STR-DE495 for £100, half the usual £200 price.
Its very chunky, but seems to be good value at that price (and I assume its better than the DE475). My only problem is that it only have 1 optical and 1 coaxial.
I know my sky+ has optical out, not sure what my Sony combi drive has though (do they always have coaxial?).
pioneer vsxc301
panasonic saxr25 (With speakers @ £350 or less)
sony strlv500 (Not that cheap)
Only good slimline amps i've heard
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
