Best Sky Receiver
Discussion in 'Sky Digital TV Forum' started by ianellison, Feb 4, 2003.
  1. ianellison
    ianellison
    I have an old Pace Sky Digibox (1.3.5 according to system information on screen). I notice Panasonic now do a sky receiver. Is there any difference in the quality of the decoded signals with an up to date receiver? Are there any other receivers other than Pace & Panasonic? Any info welcomed - reviews etc. I should have said I am feeding the RGB signal from AV1 scart into a Panny 5 using a Keene Syncblaster which sorts out the sync into V & H.
  2. ianellison
    ianellison
    Whoops - sorry moderator should have been posted in Sky + thread. Could you move it there?
  3. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    Its' fine here. Digital TV,* Satellite* and Cable
  4. Fernsehman
    Fernsehman
    Picture and audio quality is pretty much the same for all Sky Digiboxes.
    Some people reckon the SKY+ Digibox has the edge and some reckon that the Sony models are slightly worse.
    But it's very subjective and totally dependent on your connection method and on the TV compatibility - some TV sets don't work at all well with the Sky Digibox. Some sets (eg. Beko) don't respond to the Digibox remote control.
    There's a survey of TV compatibility which is worth a look.
    Fman
