Best Sky picture on a 26" lcd???
Discussion in 'LCD & LED LCD TVs Forum' started by r11ck1986, Mar 22, 2006.
Tags:
  1. r11ck1986
    r11ck1986
    Mar 19, 2006
    783
    +25
    hi,
    Im looking for a 26" lcd which will have a good picture when watching sky! any reccomendations??? i looked at the sharp LC26P50E, but i was hoping for one with PC input! not looking to spend more than £700! whats the sky picture like on the samsung???
    Thanks in advance
  2. AgentCool
    AgentCool
    Aug 5, 2004
    2,653
    Yorkshire
    +184
    Having owned the Samsung 26R41 and now the Panasonic 26LXD500 I can assure you that the Sky picture through RGB scart is significantly better on the Panasonic. Don't consider the extra £300 a burden because it is well and truly worth it, not only because of the better scart picture but it is generally a far better set all-round.
    The Panasonic also has a VGA input though it requires a bit of fiddling to get the PC picture right.
