best sky output?
Discussion in 'Sky Digital TV Forum' started by croozer, Mar 24, 2005.
  1. croozer
    croozer
    Feb 15, 2005
    115
    16
    as a relative beginner i need some advice.i have one of the first pace digital sky recievers.can i get digital sound output from it as it appears to be analogue at the rear.if not is there a skybox on the market that will give me digital sound?
  2. Roohster
    Roohster
    Jul 1, 2004
    3,870
    3
    Derbyshire
    +3,905
    Only Sky + will give you Dolby Digital 5.1.
    I believe there is a Sony box that has a stereo digital out (and therefore Nicam), but I doubt if it will be any better than your existing analog stereo.
  3. croozer
    croozer
    Feb 15, 2005
    115
    16
    will the sky+box be obsolete when they bring in hi def next year?
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Nope.
    The standard digital service is not going to be affected, it will be around for years to come.
    Of course if you get SKY+ HD it's highly likely that you can ditch an existing SKY+ since the new STB will be able to receive and record both HD and SD content.
