Best Sky+ input feed
Discussion in 'Plasma TVs Forum' started by qwiksilver, Sep 23, 2005.
  1. qwiksilver
    qwiksilver
    Is a simple scart lead the best way to connect Sky+ to the PWD8 (with a Panasonic Scart terminal board) or is there anything better that can be done?
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    I would see how you like it first......I'm sure I read somewhere that they have improved the scart connection (though to be honest it was never as bad as some make out). You can always consider the js rgb to vga converter if you think PQ could be better.
  3. gunizzle
    gunizzle
    it depends on what your doing for sound?? If you are using the plasmas audio outputs then yes that is the best way, however i use an amp that upscales s-video up to component then component out from the amp into the plasma board and im really happy with the picture quality i have to say.
    If your going for 5.1 / 7.1 surround or whatever and your buying an amp its something else to look at.
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    The s-video upconversion does work well. If you are a PQ obsessionist, you will realise that you are losing out on some picture info, and that a component video converter (from RGB) or a VGA converter is 'better' but many mortal men are happy with scart or S-video upconversion, there is not a lot to choose between them in practice, though you lose auto WSS as soon as you ditch scart.
  5. UKseless1
    UKseless1
    Mar 9, 2005
    839
    28
    +36
    Go on Martin - give us a clue, WSS?
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Kick yourself now, wide screen switching.
  7. UKseless1
    UKseless1
    Mar 9, 2005
    839
    28
    +36
    Sorry - work for a company that thrives on 3 letter acronyms. If you were listening to a corridor conversation you would think that were speaking a different language. I suppose this game is no different.
