Best Sky+HD receiver Southern Spain
GARYWARD22
Hi, What are the informed opinions of the best Sky+HD receiver in Southern Spain. I have a couple of Sky receivers - Sony - which have always outperformed the Panasonic DB30 (I know these are old but work perfectly). I also have a couple of Pace3100 which work perfectly as well. The mistake I made with them was that they do not support Sky Anytime (found out after some time). So now looking to upgrade and get a couple of HD boxes but want ones with good reception in weak signal areas - I am very close to Gibraltar so a long way south - I can actually see Africa.
If you have experience of this it would be very helpful.
fernandez
Thanks can somebody move this post there or can I do it?
Don't worry -the mods will move it if it's considered necessary.
The other way is to delete this post yourself and then repost, but the main thing is you get advice.
