Best Short focal lens Projectors under 1600?
Discussion in 'Projectors, Screens & Video Processors' started by PC_112, Apr 25, 2005.
  1. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    Hello,
    Can you suggest some good LCD or DLP projector bellow 1600 pounds with short focal lens (I should be able to get at least 92" image from 3 meters throw distance)
    I believe the Panasonic AE700E is one. Any others?
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    There's probably several that will fit your requirements, many sites have projection distance calcs eg the projectorpoint.co.uk site.
    I throw 83" from approx 2.5m with the Hitachi PJTX100 so that will be an option I think...PJ
  3. Blindman
    Blindman
    Dec 12, 2004
    108
    We project a Sony HS50 onto a 92" screen from just under 3 metres - works fine, :thumbsup:
  4. nwhitta
    nwhitta
    Feb 1, 2005
    131
    +4
    If you are also looking at DLP, the Themescene H30A is a great projector (currently £995) and should meet your requirements.
  5. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    Thanks!
    Between AE700E, Sony HS50, Sanyo Z3, and Hitachi PJTX100 which one is best for my needs?
  6. UrbanT
    UrbanT
    Jan 6, 2002
    12,876
    Aldershot, Hants
    +3,036
    So what are your needs? :D
  7. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    :oops:
    Well, apart from short throw (the bigger picture the better) I will use it in a room that I will be able to control the light and keep it quite dark. I will mount it on the ceiling.
    I will watch DVDs, some documentaries and movies on TV and play X-box.
  8. mrm3
    mrm3
    Oct 29, 2004
    2,011
    48
    Cobham
    +94
    Can you mount centrally? Z3 has a v good lens shift and can be had for under £1000 I believe now.
  9. Sprout Crumble
    Sprout Crumble
    Dec 26, 2001
    228
    +5
    HS50 also is a very flexible projector and will throw a fractionally bigger picture at a given distance than the Z3 or AE700 (not sure on the TX)
  10. Berman
    Berman
    Short Throw = More ( we call it in Germany "Fliegengitter", hm how to translate this... ) pixel raster ( :confused: ) is visible. On the Panasonic PTAE700 this effect is reduced to a minimum :).
  11. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    No I can't. I will mount it on the ceiling. I think I wouldn't mind if the image is a bit high thought. Or should i?
