Best SFF for HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by philipb, Jan 10, 2005.
  1. philipb
    philipb
    Mar 6, 2002
    2,033
    63
    Swindon
    +149
    Any suggestions for the best SFF to use for HTPC? Needs to be quiet.
    Socket 478 P4 also.
    thanks for any advice.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    SFF? Sorry, not a TLA I've see before. :)
  3. groovyf
    groovyf
    Jan 10, 2005
    78
    SFF - Small Form Factor :)
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Ah right, aka. mini-ATX. :)
    Thanks.
    In the past I used a Shuttle AMD one, quiet-ish as they go but none of them are really quiet if they get warm.
  5. groovyf
    groovyf
    Jan 10, 2005
    78
    Am currently using a Shuttle SN41G2 as a testbed PVR with MCE 2005. Noise is a slight issue, and would probably replace the PSU with Shuttle's PC40 Silent-X PSU.
    However, as I want to use two TV cards, the Shuttle's 1 PCI slot is the limiting factor. They do a 'business' model with 2 PCI slots (no AGP, but Intel Extreme inbuilt graphics solution) and that's the SB52G2 which is almost tempting me.
    The Antec Aria case is also worth a look
  6. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
  7. philipb
    philipb
    Mar 6, 2002
    2,033
    63
    Swindon
    +149
    Thanks guys - the Kloss certainly does look the biz.
    I'll do some surfing and check them out.
    Overclockers stock most of them - any other good suppliers?
  8. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    not really its from a new korean crew, so it looks like OCUK have exclusiveness for a while.
    The great thing I like about this SFF is its the first to have 2 compartments.
    The HDD/ DVD / Floppy and PSU all go below.
    The motherboard sits half way up the case, so its not effected by clutter or heat from the components below as much
  9. philipb
    philipb
    Mar 6, 2002
    2,033
    63
    Swindon
    +149
    Is it socket 478?
  10. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    afraid not its the newer one
  11. betamac
    betamac
    The problem with the shuttles is there iare just not quite enough for HCPC use IMO
    I have used one of the 240W Silent X PSU's and the 250W and both are over 35DB now i dont call that ultra silent as they are decribed
    The noise annoyed me to hell when watching dvds so i just bought a Claritas case and stuck a 14DB Silent X PSU in and wow thats what you call silent, you have trouble telling if its on or off
    Whats shuttles need is a passively cooled PSU :) not gona happen but would be ace
  12. stuartmc
    stuartmc
    Oct 20, 2004
    203
    16
    Reading
    Try taking a look at the Antec Aria. It takes a standard mATX motherboard so the choice is much wider. Because of this you can fit twin TV tuners. In a standard Shuttle type SFF you only have one AGP/PCIe and 1 PCI. This is ok if you want to use the Hauppauge twin tuner single card analogue tuner but not much good if you want Freeview.
    We use the Aria in some of our products and been very happy. Only main issue, which applies to most SFF I think, is that they can get hot and as such the fans can be noisier than ideal for a HTPC.
    More here: http://www.antec.com/us/productDetails.php?ProdID=15130
  13. groovyf
    groovyf
    Jan 10, 2005
    78
    Ah, wasn't sure of the noise levels of them. Cheers
