Best Setup for HD Sky, HDTV and DVD Recorder?
D
DragonQ
In the near future I want to get a home cinema. There are 2 options for equipment:
OPTION 1:
I want an HD Sky box (likely Sky +), a DVD Recorder and obviously an HDTV LCD/Plasma. What would be the best way to link up all this stuff? I ASSUME, the best way is as follows:
HD Sky ------(HDMI)-----> DVD Recorder ------(HDMI)------> HDTV.
However, I'm pretty sure DVD Recorders with HDMI-Out are pretty rare, let alone ones with HDMI-In. So, I was thinking maybe the best way is like this:
HD Sky -----(HDMI)-----> HDTV
DVD Recorder -----(HDMI)-----> HDTV
DVD Recorder <-----(Component + Digital Coaxial)----- HDTV
But again, there is a problem - HDTVs with TWO HDMI/DVI Connectors are again pretty rare - do they exist at all??
OPTION 2:
I may actually not get a DVD Recorder at all - Hard Drive recording (i.e. with Sky+) is a lot easier and better quality anyway, so there is less use of DVD Recorders. In this case, I will probably use the following setup:
DVD Player -----(HDMI)-----> HDTV
Or, if the TV only has one HDMI Input:
DVD Player -----(Component/RGB Scart + Digital Coaxial)-----> HDTV
Are these the best setups if this is the equipment I'll be using?? What connections would you recommend for both setups, baring in mind current technology and availablility?
