Best setup for Epson EMP-TW10H
Discussion in 'Projectors, Screens & Video Processors' started by johnniekipper, Nov 15, 2004.
  1. johnniekipper
    johnniekipper
    Hi there,
    Just got my Epson EMP-TW10H. At the moment I'm using the yellow connection (composite ???) from my DVD to the projector. My DVD does not have Component out. Would I be better using a 5M s-video cable or a scart cable out of the dvd into the scart/component thingy that came with the projector ?
    Also any recomendations on a screen ?
    Any advice on getting the best out of it via menu settings ?
    Thanks in advance
  2. MikeRJ
    MikeRJ
    Oct 21, 2004
    229
    Plymouth
    Use the RGB adapter that came with the projector, and the quality will be very simmilar to using a component connection. The only downside is that progressive scan will not be available.
    Composite is by far the worst connection you could use, you are really short changing yourself by using it!
  3. RichMercer
    RichMercer
    If he doesn't have component out on his DVD player it wont be progressive scan anyway. ;)
