best settings for panny 6 and xbox
I
iwilliams
Hi all
When watching TV I use the picture mode NORMAL or AUTO.
When using this setting on XBOX ( wired using the RGB cable )
its quite dark.
So I switch to dymanic, its quick and very bright. But isnt the greatest picture...
What would anyone else sugguest?
Colour up/down.brightness,etc etc etc
If I plug the xbox into the CRT TV the pictures seems cleaner
that the panny when switched to dymanic mode,
symanski
Established Member
I've got mine set for Cinema, going in via the component input to a five series. I've got the XBox connected via Sky to an RGB to Component converter before going to the plasma.
White balance is normal, but sharpness is turned down a tad to give a more cinematic effect.
All the best,
Dr John Sim.
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
