Best settings for Hitachi 42PD7200?
Discussion in 'Plasma TVs' started by azz, May 16, 2005.
  1. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Just got this and impressed
    I wonder if some one could guide me to the best settings for this TV and also
    were to get a HDMI dvd palyer from but will it make a real differnce over component.
    The TV is good but does not itself do progressive scan-my dvd palyer is tosh 330E-will hdmi really make a big diff with this set.
    Can anyone else tell me whether set came with any minor cosmetic damage-mine has a some paint missing from under the stand on the front right hand corner and the screen rt hand bottom corner alluminium has been caught on something?
    What should i do ? My main night mare was dead pixels and this TV has none that i can spot or buzzing.
    Azz
    :lease:
  2. ajbeech
    ajbeech
    Jan 7, 2003
    57
    My screen arrived with minor damage to the right-hand side speaker. I contacted the shop - they are speaking to Hitcahi to get the speakers replaced under warranty.
    Still playing with my settings at the moment, used the following as a starting point (see towards end of page 1)
    http://www.avforums.com/forums/showthread.php?t=168163
    No comment on HDMI - Component looks excellent to me right now, so no need for me to upgrade my player yet.
  3. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Thanks for reply.
    Sorry for my spelling but thanks for that
    I want to make sue everything works before the 28days as i do intend to use the HDMI but only if signif difference
    Azz. I will ask my retailer to get things sorted
