Best settings for contrast/brightness etc
Discussion in 'General TV Discussions Forum' started by HMHB, Jan 6, 2004.
  1. HMHB
    HMHB
    Nov 11, 2001
    26,462
    Nottinghamshire
    +5,084
    I've had a Panasonic TX-32pb50 for a while now and was messing about with the contrast and brightness last night to try and get rid of a kind of a "heat haze" around objects on the screen. Is there available any advice on the best way to have the brightness/contrast/colour/sharpness etc set up ?
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,320
    Somewhere in South Yorkshire
    +5,675
    Probably the best/easiest thing to do is search your DVD collection for a title with THX branding. If you don't have one, buy one (eg Indiana Jones Trilogy). Then look on the disc menu for the THX Optimiser and follow the on-screen directions.
  3. HMHB
    HMHB
    Nov 11, 2001
    26,462
    Nottinghamshire
    +5,084
    Aha - I didn't realise there were disks that could do that !
    I don't have a problem when watching DVDs, it only occurs on terestrial/SKY viewing, but it would be a good exercise to set things up properly
  4. Mylo
    Mylo
    Mar 13, 2003
    5,545
    +372
    Monsters Inc has it as well John. I used mine last night to calibrate the sound levels.
    Regards, Mylo:smoke:
  5. NAI
    NAI
    Dec 12, 2003
    257
    TBC
    +16
    if you say DVDs look good then it may be the reception and not the settings. use a RGB scart and set your sky to output and RGB signal and it may clean up the picture.
  6. HMHB
    HMHB
    Nov 11, 2001
    26,462
    Nottinghamshire
    +5,084
    I'm using an Ixos scart cable into AV1 (RGB) and have it set for RGB on the Sky box. All this seems to give me is a more saturated picture.
