Best second hand dac for £500
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Higibuilder, May 2, 2017.
  1. Higibuilder
    Higibuilder
    Mar 10, 2013
    1,126
    Birmingham
    +100
    As above please guys .
  2. muljao
    muljao
    Jan 24, 2017
    2,070
    116
    Ireland
    +752
    Not enough info/ do you need usb, optical , coaxial, all of them?
  3. Higibuilder
    Higibuilder
    Mar 10, 2013
    1,126
    Birmingham
    +100
    Hi sorry
    It's to be used for my Shanling cdt100 player so I can use it as a cdt so just coax in .
    At the moment I'm using a Audionote Dac 1
  4. Deleted member 781788
    depends on your luck and the day, you actually want to purchase.
    M-DAC is a very tried and tested quality DAC.
    But if your budget can go up a little, I have heard fantastic stuff about this one.
    Wyred 4 Sound DAC-2 | eBay
  5. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,276
    Welwyn, Herts
    +942
    I'm sure you can get a Benchmark DAC1 for £500.
    Nick
  6. Deleted member 781788
    Good DAC - but no USB - so future upgrade or use is limited.
    Not in the class of Wyred4sound though.
  7. muljao
    muljao
    Jan 24, 2017
    2,070
    116
    Ireland
    +752
    I'm not so sure if the difference in DACs is that much to warrant huge spends, but then again I'm not so experienced with really expensive stuff.
    My friend bought an Arcam irdac 2 the other day for 300 pounds new. Loads of inputs and I thought it sounded great. It does more thought, it's a preamp and headphone amp also. This may imply its less if a DAC but I was well impressed. Didn't get to try headphones, but as a stand alone DAC it's rather good
  8. Higibuilder
    Higibuilder
    Mar 10, 2013
    1,126
    Birmingham
    +100
    Thanks for the great info guys
    USB etc will be no use as I've separated my hifi from my AV so really its cd playback only . Was hoping to find the most simple yet great sounding unit within my budget .
  9. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,533
    +4,260
    If you have £500 to spend, I'm curious why you are looking for a USED DAC. I mean fit that is what you want, fine. but there are some very nice NEW DACs around £500.
    Cambridge Audio - DACMagic 100 - Richer Sounds
    Cambridge Audio - DACMagic Plus - Richer Sounds
    https://www.hifix.co.uk/hi-fi/hi-fi...-to-analogue-convertor-inc-bluetooth-and-aptx
    Audiolab M-DAC Digital to Analogue Convertor - Superfi
    The Cambridge Audio DACMagic Plus (24b/348k) has 1 input withe Optical/Coaxial, a second input with Optical/Coaxial, and a third input with USB-PC. Priced at a very reasonably £250.
    The Audiolabs M-DAC is just trace over budget NEW, but the various iteration of the M-DAC should be available for a very attractive price USED.
    The ARCAM irDAC is not only a DAC, but also a Bluetooth APT-X Receiver, and easily priced under your budget.
    The more modest Cambridge Audio DACMagic 100 (24b/192k) is well under your budget and has Optical/Coaxial and USB-PC Inputs
    In used, certainly consider CHORD DACs which are generally very well regarded.
    Steve/bluewizard
  10. Deleted member 781788
    Far be it for me to try to change your mind, just a little info:
    USB is for Hifi use only! I have not seen it used in AV systems (but haven't seen everything yet).
    It is used when you have your music either downloaded, streamed or ripped into your computer, which could be of higher quality to your CD's - there are SACD rips, high definition audio streaming services avaulable - CD's are merely 16bit -44.1KHz , these days we are talking 24bit 88.2KHz and better, even on some back catalogues!
    Most computers do not have any other means of outputing pure untouched digital music save for USB and network.
    Should you decide to include a computer to your hifi system, you'll find the lack of USB disturbing.
    Besides, if a DAC has no USB input, it is most probably an older design.
    on the other hand if it has network facilities (wifi or wired) it is most probably the latest design.
    P.S. the Wyred4sound DAC I had mentioned, is sold now - it was really cheap for what it was.
