Best Satellites???!!!
Discussion in 'Home Cinema Speakers' started by Les E, Aug 19, 2005.
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    What would people consider the best satellite speakers on the market at the mo? I have been looking at the Anthony Gallo Nucleus Micro Satellite Speakers?
    I would need a 6.1 set-up too! :D
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    There is no such thing as "best" as one man's meat is another man's poison as they say.
    Anthony Gallo speakers have an enthusiastic following on the forum but I will be the first to admit that I am not one of them as I think that they are too dependant on the partnering equipment and although I have heard them sound pretty good I have heard them sound pretty poor more often.
    If you are interested in small round speakers have a look at the Orb speakers which some say sound better but only cost half the price directly from the American manufacturer.
    I assume that as you are posting in an AV forum that you are looking at AV rather than hifi speakers. If that's the case why not check out the M&K K range of speakers which are rather good.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,882
    The Borders
    +3,117
    Ian Ian Ian...
    How can a copy cat design sound better than the original - if the originals are tricky to integrate with source and room I'm sure the copy cats will be just the same!
    Les E - as Ian says there are no 'the best' satellites; nor anything else for that matter in this market.
    The Anthony Gallo Micro's and A'Diva's you ask about certainly cant be the best - otherwise Gallo would not be in the process of releasing the slightly more expensive Ti range; which by all accounts are a worthwhile upgrade to the original and still very viable 'originals'.
    See http://www.roundsound.com/micro.html
    If you want more 'traditional' looking cabinets then Ian's recommendation of M&K is very relevant - though keep in mind the entry level K-Series require a decent amplifier (that's 4 ohm compatible) to get them working well.
    Your signature says you have the KEF KHT - I wonder would you be better to aim high and build towards your aspiration rarer than simply swapping out an entry level sub/sat package for something that's one step up the ladder.
    Best regards
    Joe
  4. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    Have you looked at the larger kef satellites?
    I have the KHT 9000 Ace speakers for my front sound stage and I find them superb. For something a little smaller the new 6000's look good, also using the 'ACE' technology, although I haven't heard them yet.
