Best S-Video cable for PS2?
Discussion in 'Cables & Switches' started by TJChelsea, Jan 11, 2005.
  1. TJChelsea
    TJChelsea
  2. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    I have the 'Monster' PS2 S-Video cable. It's very good although from what I can remember a bit pricey.
    I can't compare it with any other because I have only used this type, although to be honest it's probably a bit excessive, the PS2 is probably the limiting factor in terms of PQ
  3. AMc
    AMc
    Nov 20, 2000
    5,823
    Near Norwich
    +2,342
    I used a Logic3 cheapy (£5 from HMV) and it was fine in comparison with an official RGB lead - there was little to choose via my Sony 32" CRT. I'm not sure there is a lot of point in attaching a cable that costs 25% of the console but other's mileage may vary.
    I'm now using the RGB lead and projected at 1.8m wide it still looks great.
    If you're feeling mean get the £5 job, if you're feeling a bit flasher then get the SOny official one or the Monster if you're feeling very flush indeed!
  4. stefmcd
    stefmcd
    Nov 7, 2004
    591
    +7
    Toysrus have a Power-on cable at 3 quid - picture quality is fine.
  5. Mr..Smith
    Mr..Smith
    I know your asking for s video, but ive just ordered a 3 way component box from lik san (in the ps2 cables bit), so that i can have my ps2 xbox and dvd player all through component. its cheap and might be a better option than s video picture wise.
