Best -RW or +RW media for compatibility?
Discussion in 'Blu-ray & DVD Players & Recorders' started by retrof, Jan 19, 2005.
  1. retrof
    retrof
    Feb 28, 2001
    155
    +14
    Hi All,
    I'm using my PC as a DVD recorder, and I have the option of using -RW or +RW discs (just using is as a basic dvd recorder for timeshifting, and want to re-use discs). I'm wondering if anyone has any experience of what media is best for RW use, and whether it's better to use -RW or +RW for compatibility with standard DVD players? - I'm quite aware of the differences between the two formats, and don't want to start another formats debate. What I'm looking for is opinions from avforums members on which format, and which brand of media work best for you for rewritable use?
    Thanks in advance.
    -rf
  2. captainpacific
    captainpacific
    Jan 9, 2005
    261
    Hampshire
    +51
  3. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    They are pretty much identical.
    If you look at the results reported on http://www.videohelp.com, each show 80% compatibility.
    I like Verbatim -RWs... but apparently it is the actual dye manufacturer which is more significant... still they have always worked well for me.
    Mark
  4. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,434
    Reading
    +170
    Personally I use Imation, TDK and Philips for +RW. All work fine on other players / drives for me.
