Best router for 20mb bb
Discussion in 'Virgin Media Broadband' started by furs307c, Sep 11, 2007.
  1. furs307c
    furs307c
    Jun 3, 2006
    429
    +11
    Hi can anyone tell me simply what is the best router to use for virgin 20mb bb
  2. RAINS
    RAINS
    Oct 7, 2005
    524
    Birmingham UK
    +32
    I'm using and have been for 2 year a linksys with no problems.:smashin:
  3. Jayceef1
    Jayceef1
    Dec 3, 2005
    Gravesend
    +11
  4. AndySnapper
    AndySnapper
    Sep 25, 2007
    4
    That Belkin N1 is quoted at being over £1200. If that's right I will have to pass this time :rolleyes:
    Andy
  5. AndySnapper
    AndySnapper
    Sep 25, 2007
    4
    I am also on Virgin 20Mb and bypassing my router (SMC7004ABR) I get the full whack of 20Mb mostly. Unfortunately the SMC is not capable of delivering more than 10Mb (confirmed by SMC).
    I am amazed how poor the information is out there on what DSL routers can support this speed effectively. The information on the boxes is equally dreadful and the PC World tech people, well I had better not go there :censored::thumbsdow
    I guess that I will have to go wireless now as that seems to be the fashion (even though I have no other need at all to do so).
    Is anyone else using a compatible router with Virgin Media 20Mb?
    Cheers!
    Andy
  6. bullfinch
    bullfinch
    Jul 3, 2006
    193
    Well I'm no expert but it seems to me you get 54Mbps routers and 108Mbps routers, and I would reckon for 20Mb the 108Mbps is the one to go for. But I may be wrong, perhaps someone could clarify?
  7. AndySnapper
    AndySnapper
    Sep 25, 2007
    4
    Thanks for the reply Bullfinch
    I think the 54mbps and 108mbps refer to the wireless transmission rate and is nothing to do (directly) with the isp's download throughput.
    The industry does have a knack of making things far more complicated than necessary.
    Andy
  8. ]|EGG|[
    ]|EGG|[
    May 22, 2002
    152
    Dudley, West Midlands
    +4
    Out this month and the USD RRP is $200 and a UK RRP of £98 apparently, bit different from the £1200 quoted above!
  9. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
  10. Ned Senior
    Ned Senior
    Aug 14, 2006
    4,818
    Stalag 9
    +1,170
  11. chris57
    chris57
    Aug 25, 2006
    1,149
    UK
    +157
  12. Jayceef1
    Jayceef1
    Dec 3, 2005
    Gravesend
    +11
  13. RoNaLdiNhO
    RoNaLdiNhO
    Mar 2, 2006
    293
    +11
    Linksys WRT54GL is what i use, even better after you smack on a hacked firmware on it :p
  14. jryoung
    jryoung
    Aug 8, 2000
    35
    Wiltshire,UK
    It is vitally important to have a newish router with a 100mbps uplink speed to your Cable modem (which also needs to be fairly new). I had to get NTL to upgrade my router (which they now acknowledge on their web site), and then bought a new Netgear router, with Gigabit lan, and 100mbps uplink.
    Most older routers and cable modems have a 10mbps uplink. Many new routers still do.
  15. edenedits
    edenedits
    im using a lynksis router and have been for quite a while now, i have had very bad experiences with various types of belkin hardware and would suggest staying away from that.
  16. Sooty
    Sooty
    Feb 7, 2005
    33
    9
    Nott's
  17. steery1
    steery1
    Oct 1, 2007
    A different planet
    I'll be having VM install TV, phone and BB to my house in a couple of weeks time. Can anyone tell me what modem the installer should fit in order for me to be able to receive the full up to 20Mb speed? :)
    I've heard tales of the installers not fitting the correct modem thus preventing customers from achieving the best speed possible. Also when some customers have upgraded to the 20Mb service from a slower one their modem could not process the full speed.
    I'd like to check when its being fitted that its the proper one so I dont have to spend ages with CS asking them to send out a new modem. :)
    I'll also have to buy one of the routers recommended in this thread for my network. :smashin:
  18. essdee
    essdee
    Mar 8, 2005
    22
    3
    I would expect you to get an Virgin Media 255 (made by Ambit). I have a 250 which is pretty much the same apart from the branding and the 255 only has ethernet (no USB). Data sheet for the 255 here. A 200 may also be ok, however don't accept a 100 or 120. Unlikely you would get one of these anyway, but you never know.
    I also use a Linksys WRT54G with DD-WRT firmware and can get up to about 16Mb wireless and get over 19Mb when hard-wired.
    Hope this helps.
  19. steery1
    steery1
    Oct 1, 2007
    A different planet
    Nice one essdee, thanks. I'll keep an eye out for it. :thumbsup:
  20. DarkEntity
    DarkEntity
    Feb 13, 2005
    2,584
    2
    137
    Glasgow
    +606
    There is no "Best" router. D-Link, Netgear, Linksys and a few others are probably the most well known names on the market. Get one that is Wirelss and supports the "N" standard and one that has Gigabit LAN as if its a new PC itll probably have gigabit ports.
    Other than that look for one that suits your needs. If you want robust reliable go for one of the above (although ive had nothing but problems with Netgear others love them) Ive got a D-Link Di624 which atm is doing great (although will be getting replaced with a gigabit and N class wireless model soon.
  21. tonyk79
    tonyk79
    Feb 24, 2006
    1,335
    63
    +192
    I have a Linksys WRT300n Router and it acheives the maximum download speed from Virgin. I have it running two PC's , 1 HP Laserjet printer and 1 Xbox 360 via cat 5 cabling and another Xbox 360 and Laptop via Wireless.
    Granted most of this does not run at the same time but I can not fault the router or the bundled Wireless card (300mb Laptop card). Below is a link for, in the UK it is a silver and black colour as opposed to the picture shown and is a Version 2.0 which had firmwire updates.
    http://www.linksys.com/servlet/Sate...513404&pagename=Linksys/Common/VisitorWrapper
  22. chumley1
    chumley1
    I have a motorola SB5101E modem (you might have to ask for it as they may give you a telstar or something similar, which in my view are no comparison) along with a Belkin 2.4ghz wireless router (allows for both wired and wireless connections) WEP security. Keeps everything steady. This is not all you have to check on.
    It also depends 'where you are in relation to the cable. What I mean by this is .... in my case we are at the end of the cable on my street, noone else after our house, the end of the line so to speak. This means as the signal is brought up, there are alot of people between us and the main cable point down the road, thus putting us at the wrong end of a drain on the strength of connection. Imagine a hose connected to the tap (main connection) and you are at the spout end. Now everybody between you and the tap is a hole in the hose. Your strength at your end of the hose diminishes.
    I managed to get a decent engineer so instead of just one cable connecting my house we have 2 cables coming in to help with the connection upkeep :smashin:
    Hope this helps
  23. TimeLord
    TimeLord
    Dec 3, 2005
    350
    +53
    i have the D-Link DIR-655 Xtreme N Gigabit Router.
    id give it a 9/10. when vm is running as it should i get some great speeds :thumbsup:
    [​IMG]
  24. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
    Anyone bought a Belkin N1 Vision yet ? I'm on the brink !
    Steve
  25. Jayceef1
    Jayceef1
    Dec 3, 2005
    Gravesend
    +11
    I have a Belkin N1 Vision. works a dream (so far, only had it a week) and get around 19Mbs when the connection is maxed out.:thumbsup:
  26. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
  27. bradfitt
    bradfitt
    I have the belkin also. Not only does it work great it looks great as well. Downfall is I can't help playing with the display got to keep touching those buttons hope the fad wears off soon.
  28. DarkEntity
    DarkEntity
    Feb 13, 2005
    2,584
    2
    137
    Glasgow
    +606
  29. guvvie
    guvvie
    Aug 24, 2005
    756
    46
    +134
    Have you managed to connect the 360 wirelessly to your wrt300n using the newest 2.0.20 firmware???
  30. sotonjoe
    sotonjoe
    Aug 16, 2006
    611
    28
    +40
    I'm completely confused now.
    I've purchased a dlink router kit dkt-110 which contains a dir-301 router to use with my 20mb connection. However, I can't for the life of me find whether it is able to support a connection up to 20mb. The only data I can find is with regards to it's wireless data transfer rate across a network which is 54mbps.
    I'm a little concerned that it is only designed for use with slower questions so I've emailed dlink for confirmation. Is there anyway i can test the router to find out myself? Or perhaps somebody might just happen to know!?!?!?
    The weird things is that when you look at the specs for some routers they boast about their ability to handle faster internet connections up to 24mbps etc so a failure to include any info on my router's spec makes me think that it might only support up to 8mbps etc.
    Any help / advice greatly appreciated!
