Quantcast
Best RGB to plasma vga converter
C
candg
I have a Panasonic series 5 ,42 " Plasma screen
I need to be able to use the VGA input for an RGB Sky Plus connection.
I am totally confused by some of the postings on this subject.
Which is the best (and most reasonable) way to achieve this..is it the JS tecnologies converter, the Keene Syncblaster, or something else ?
Any help would be appreciated
Many thanks
Graham
rscott4563
JS tecnologies converter :smashin:
Dutch
What Ryan said!:smoke:
Steve
forrestgump
just done the same myself but decided to try the lektropacks converter which is a lot cheaper than JS, good thing is if you do not like it send it back within 7 days for a refund, happily I have connected my sky box via rgb scart to converter to 3 phono to vga and it looks a lot better than via scart only, money well spent in my opinion
stormjai
does js converter still allow aspect ratio switching (ie widescreen to full screen )from sky+
thanks
CARLOS
thanks
No, You would need a Aspect ratio controller as per Powerbuys forum !
Another vote for the JS unit :smashin:
forrestgump
guys, you are all voting for the JS unit, has anyone tried any competitors product, if not how do you know Dr Simms is better? I suppose if the Beekeeeper endorses it it must be the dogs b...ocks
Nic Rhodes
I have tried several of these 'boxes' and the JS SVideo / RGB box and the RGB / VGA were the best I have seen by some way. Just bought a RGB to component second hand JS to try, just need to borrow a RGB SCART player again. Never tries his SCART switcherbut most of you know what I think of SCARTS :) All of JS stuff just seems to be quality in plain boxes. This guy both knows what he is doing and doesn't make unnecessary compromises in quality. He is one smart cookie in my book.
C
cheeseburger
I use a QED Q sync scart to VGA and find the Sky picture is pin sharp.
Years ago people said the earth was flat!
C
candg
Thanks for the feedback guys,,,looks like the JS tech thing then.
Now all I need to be able to do is make my own RGB lead up. Out of necessity I have to use 10 core AV lead from Maplins as this is the only diameter lead that will fit through existing floor conduit. The lead has to be about 25 metres long to get from one room into the AV room. Can anyone suggest how I can get the Scart pin configurations to make my lead. Also what is the miniumum number of connections on the scart an for RGB to RGB only lead. I do not require Composite or audio to be fed through.
Many thanks
Graham
symanski
Graham:
SCART pin-out is on my website - in the Technical section.
We've had many customers trying out alternative solutions, all of them. Because we're using broadcast quality components, and a unique computer enhancements, when the action starts to get frantic on screen, my design is still able to lock to the picture. It also allows you to choose the best quality leads both for input and output. I personally use a Bettercables VGA lead, and quite frankly it really is an amazing lead.
All the best,
Dr John Sim.
C
candg
Thanks for your comments John. I have been trying to access your website for a while ...it appears to always be unavailable. Any ideas ?
Graham
C
candg
I have found your website..but no link to a technical section for the scart pin connedtions. Maybe you could advise me on my problem before I buy the RGB to vga box.
The converter box needs to be about 6 metres from the screen..due to installation problems. I am currently using a bog standard vga lead from Maplins as a PC input..the results are surprisingy good.
The rgb input of the box will have to be via a custom made rgb only lead..this has to be as thin as possible to fit it through an existing underfloor conduit I think the maximum thickness could be about 6mm..this is where I have the problem.
The reason that the lead is so long is due to the fact that Tivo and Sky plus are in a different room (this has to be the case as tivo is supplying an all house wired AV connection.
I have soldering skills and could easily solder one scart plug on the end of the lead. How many pins would need soldering for RGB ? Ideally I would like to get a custom made rgb only lead with one end soldered and one end free for me to solder after the lead has been passed through the conduit. ..in the perfect world this lead would also carry a digital coaxial audio connection to run the digital audio output of the Sky plus into the other room and into the second AV amp. Any suggestions ?
Thanks again
Graham
Similar threads
Trending threads
