I recently purchased a tv from argos which has 1440 x 900 as its native relution. is there anyway to set this resolution for my 360? Using the component caples i only get the option of 720 or 1080 and with my vga cable i dont get that res as an option either. if there is no way of setting it then which resolution do you think will work the best. im currently using 720p which means im down scaling but the picture is still really good.
also i need a cable to connect my pc to my new tv and i have no idea what i need so does anyone no what i need? any help would be appreciated thanks.
