Best remote
Discussion in 'Home Cinema Control & Remote Controls' started by kriswood5, Nov 15, 2004.
  1. kriswood5
    kriswood5
    Hi there guys
    I have recently bought a Panasonic Plasma to go with my Pioneer DVD, receiver and Sky+. However, I now have 4 remote controls which is quite inconvenient and confusing.
    So I am in the market for a programmable remote control and was wondering which is best from an ease of use and usability perspective. I have seen a lot of messages relating to these remotes: Marantz RC5400, Philips Pronto and Harmony.
    Any comments, viewpoints or recommendations on the above would be gratefully received.
    Sorry if this has been asked before but I have tried searching the forums without any real joy so far.
    Many thanks
  2. kriswood5
    kriswood5
    Having not had a response, I wondered if anyone knows where I can go to read reviews on various remote control devices?
  3. stevebez
    stevebez
    Jul 11, 2004
    489
    +13
    First thing I did when I thought about getting a master remote was if I was going to go hard buttoned or touch screen.
    Initially I thought touch screen better although - I really like fixed button remotes - esp the tactile feel and familiarity of button position of this type remote and went for this.
    Thats step 1.
    Step 2 : You then need to decide if you require RF as well as IR functionality.
    Step 3 : Decide on your budget!
    Step 4: Decide on your remote!
    It then comes down to personal preference but I reckon ...
    Home Theatre Master MX500 for IR only hardbutton
    Home Theatre Master MX850 for IR&RF (in black) hardbutton
    Touchscreen -> Pronto Pro RU950 / RU980 depending on RF requirements and if you want colour screen.
    Good Luck!
    Rgds Steve.
    P.S I have ordered an MX850 and I should have it shortly will report back then.
  4. wbessada
    wbessada
    Sep 5, 2003
    1,560
    38
    London
    +17
    kriswoods I'd highly recommend www.remotecentral.com which although a US based site has indepth reviews on almost every remote.
  5. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    The Harmony H655 is great, see the other threads relating to it. :thumbsup:
  6. kriswood5
    kriswood5
    I will check out remotecentral - thanks for tip.
    I am starting to lean towards the 655 as it seems well thought of on this forum. I had a demo of a Marantz 5000 today from a work colleague, pretty good functionality but seemed like a real big headache to program. I do not want to spend too much if possible and the H655 is £99 on Dixons web site so this is attractive.
    Thanks for replies
  7. ancientgeek
    ancientgeek
    You can see what I have below. Using just the Sky+ remote with codes entered for the screen and Amp, I can do all the common functions on the screen and amp. (inc. Screen on/off, amp on/off, amp volume, amp input select) Still need another remote for the DVD though. I find that Sky+ is the comonest use of the whole setup anyway.
    Just a matter of researching the codes for the Sky+ remote.
  8. NC11
    NC11
    Sep 19, 2004
    457
    London
    +7
    i consider the remote to be another piece of kit within the HC setup. as such , i checked the prontopro , marantz rc9200 and the rc9500. i'm now using the 9500 and have configured it myself (simple once you get the hang of it). i plan to add lights control next month as well.
    i prefer the marantz's build and feel to the pronto's. it also works better with the various items in my setup (mainly the amp).
    not sure what budget you have in mind , but if you spend (?) grand on you're hc kit , investing in a good reliable remote to control it all seems a sensible purchase.
    HTH.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    with the harmony H655 £99 at dixons its a no brainer from where i sit.....
  10. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    What would make you go for the Harmony rather than a Kameleon (2nd generation)? Are there functions that you can't set up on a Kameleon that you can on a Harmony?
    One For All say they have sorted out the battery life problems with the new ones, so that shouldn't be a problem..........
    I'm asking beacause I'm expecting to receive my new Kameleon in the post tomorrow, but I'm thinking of returning it and ordering a Harmony from Dixons.
    Advice would be appreciated.
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    well h655 has loads more activities is much cleverer and a better product......
  12. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    Oh no it's not. It's Canadian. :p
  13. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    Things that I did not like about the Kameleon (others may disagree)
    1. The auto turn on was incredibly sensitive, often a sneeze was enough.
    2. The unit buzzes when on.
    3. The unit uses batteries very quickly.
    4. Even though only the keys that are used for the particular device come on, the unit can only display the keys that are printed on the surface. This meant they could be difficult to match to the actual device. You were left with some unused keys appearing and other needed keys not appearing. It is possible to map functions to unused keys, but this means remembering their actual function when you come to use the device.
    Things that I like about the Harmony.
    1. All buttons, hard or soft are fully mappable with any function.
    2. Learns all the commands of the original remote.
    3. Any functions not represented as hard buttons can be displayed as soft buttons on the lcd screen.
    4. While each device can be controlled independently as a device, the trump card of the remote is that it has activity buttons, e.g. watch tv or watch dvd. When one of these is pressed, it turns everything needed on, everything that is not needed off and changes any settings e.g. tv input to the correct one. All activities are again fully customisable.
    5. It has a built in tv guide (I have not tried to use it)
    6. Battery life is far superior.
    7. It doesn't buzz.
    Those are my views. :hiya:
  14. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
  15. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    Personally, I'd go for the Marantz, but I would say that since I've got one.
    Seriously, having bought an RU890, then a 940, then a 950, I must confess to slowly loosing faith in Philips. Dubious quality control in both the hard and software departments, I got tired of them apparently using Joe public as their beta-testers. Indeed my experience was such that I was fast loosing faith in the whole LCD concept; I started scouring the web for a hard button alternative.
    Alas, there isn't one, or certainly not one as flexible. The HTM MX-700 did come close, but it's missing a number of buttons that I would consider essential (most notably, the four colour and instant record). Salvation then appeared in the form of a 9500, which I stumbled across on e-bay (and was going for an absolute steal of a price).
    Essentially the units are the same. The Pronto does have four user buttons whereas the Marantz only has two. Conversely the Marantz has a true forward and back function, the Pronto does not. However, what swings it, in my opinion, is the software. I've found Wizz.it to be far more stable that ProntoEdit NG ever was. Don't take my word for it though, check out the Pronto/(Marantz) forums at RemoteCentral; and whilst your there (assuming LCD is the way you really want to go) you might also want to check out responses to the HTM MX-3000 in the Home Theater Master Forum.
    David
  16. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
  17. rab4169
    rab4169
    Dec 12, 2004
    533
    i have 2 theater master 500`s ,which if you look at customer reviews on remote central got the highest score , if you are going to america you can get for £40 , brilliant remote
  18. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
  19. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
  20. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Most of the "One For All" remotes can be have increased functionality via JP1 reprogramming http://www.hifi-remote.com/jp1/help/index.shtml
    I use one of these which is about £25
    http://www.oneforall-int.com/english/products/urc/URC-7562.htm.
    Using JP1 you can set up the remote via a PC. With mine now, pressing any of the device buttons, switches on all the correct equipment and switches to correct TV input.
    It is very powerful but granted it takes a bit of effort getting started and understanding the bits of software you need. However you cannot deny it is a hell of alot cheaper than some equivalent remotes.
  21. MPK
    MPK
    Nov 26, 2004
    479
    London
    +8
    You could also simply go on ebay and buy a Harmann Kardon & Microsoft TC-1000 for about £20 I've had one for years and was very happy. Have the all-in-one Denon now that comes with the A1, but it's not as practical as my old one. The touch screen is fully programmable via PC and the buttons can be renamed as you wish. It lists activities such as "Watch DVD" where you'll find all the necessary buttons combined from your amp, DVD player, TV, etc.
    It's discontinued now, but used to be one of the best you could find. Here's a review: http://www.homecinemachoice.com/rev...armanKardon/HarmanKardonTakecontrolTC1000.php
  22. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
  23. Family Guy
    Family Guy
    It's older than the 980...it's basically a Philips Pronto RU970...
  24. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    So what is the best HARD-BUTTONED remote control
    ...I doubt there's anything that can rival the Pronto RU980 or the Marantz RC9500, but I would like to look at all options before plunging in.
    (would also wait if others are soon to be released that you know of)
  25. Family Guy
    Family Guy
  26. czzer
    czzer
    Mar 2, 2005
    719
    43
    +105
    Harmony 880/885 is the only way to fly!
  27. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
  28. Family Guy
    Family Guy
    Where can it be had in the UK?
  29. jamie110
    jamie110
    Apr 8, 2005
    355
    Walton on thames
    +16
  30. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
