best registry cleaner ?? worth it ??
Discussion in 'Computer Software & Operating Systems' started by Oggie, Jan 17, 2008.
  1. Oggie
    Oggie
    Jul 11, 2007
    7,071
    +619
    i have read that its worth getting registry clean software, dont know much about it so would like your opinion. is it really worth it and which one is the best ( any free downloads) ??
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    I use this http://www.ccleaner.com/ its freeware and has registry cleaning as well as cleaning all the junk from your main C drive.:thumbsup:
  3. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
    I don't use a registry cleaner because I run into problems a few years ago having one, but a lot of people use ccleaner and its supposed to be ok and its free http://www.ccleaner.com/
  4. mjcairney
    mjcairney
    Oct 26, 2003
    7,271
    2
    137
    Airdrie, Scotland
    +1,074
    I use a Registry Cleaner called RegCure which I paid for but, although all the advertising hype said that I would see all sorts of improvements in the speed of my PC, I have to say that I have never noticed any difference and would definitely not buy again.
    Hope that helps you make up your mind.
    Cheers,
    Martin.
  5. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,579
    +6,591
    I use ccleaner too... and whilst I don't notice a performance boost as such (probably placebo!)... I do appreciate it removing all the cache files after I am done with the internet looking at the space I recover :p btw be sure to untick 'delete url/history' for browsers in the settings with this program. If you misspell a url or something you can always manually highlight-> shift+delete :)
  6. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,569
    The Shaolin Temple
    +43
    Another vote for CCleaner -small file, fast and effective as mentioned for removing all temporary files and cookies etc and as a registery cleaner.
  7. Sofix
    Sofix
    Even I have tried many registry cleaners mentioned with different success rates but I got best results with registrycleanfix, ideal for professionals like me. It’s available at http://www.registrycleanfix.info/ Hope you will get it suitable too.
  8. Stiggy
    Stiggy
    Dec 7, 2004
    6,725
    Sandy Heath
    +1,043
    I'd say don't bother.
    I wipe and reinstall my PCs at least once a year. It's like getting a new PC again each time.
    If you're smart and install Windows on C: and put all your data on D: it's a doddle. Redirecting My Documents to a folder on the D: drive makes your life simple for future installations.
  9. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    And not using the 'my documents' system is even better ;)
  10. doublej
    doublej
    Jul 3, 2005
    122
    +13
    Hmm..... registry cleaners...... once thought of an essential but more recently exposed as snake oil.
    http://itqueries.com/?p=63
    the latest thinking - and I agree with it - is that there's no need to clean your registry, in so much as there are no consequences or penalties of an 'unclean' registry.
    The architeture of the windows registry (its pretty old) means that its size and contents have no impact on its performance.
  11. wormvortex
    wormvortex
    May 29, 2005
    5,757
    South of Heaven
    +442
    from Wikipedia
  12. greshoff
    greshoff
    Nov 19, 2006
    405
    +3
  13. dave_bass5
    dave_bass5
    Jul 6, 2004
    6,741
    London, centre of the universe
    +637
    I use JV16 power tools.
    While i don't use it regularly it does come in handy for tracking stuff down.
  14. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    I used to use RegSupreme.
  15. stevos
    stevos
    May 16, 2004
    6,178
    +579
    I have used reg cleaners in the past with mixed results. However my laptop seems to have come to a grinding stop and so i will give cccleaner ago before reinstalling vista (not expecting that to be fun).
    I just wish there was some cheap easy software that would get your computer back to fighting form without formatting / reinstalling. As the idea of reinstalling World of Warcraft and its 100million addons doesn't sound like much fun.
  16. doodles
    doodles
    Mar 20, 2006
    424
    +25
    used once but can end up with more problems, you just dont know what its cleaning:rolleyes:, dont use anymore...
  17. treacle
    treacle
    May 17, 2006
    598
    +16
    CCCleaner a placebo for those that need reassurance..
  18. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,891
    2
    The Fylde Coast
    +13,532
    Every time I run a reg cleaner I always end up with some issues or another. Last week I ran RegCure and it screwed up my installation of Microsoft Home Server. Had to reinstall it to get the console to load properly.
    I must put a sticky on my PC " DO NOT RUN REGISTRY CLEANERS. PERIOD".
    Semi rant over.
  19. Fozzzeee
    Fozzzeee
    Jul 21, 2006
    38
    Hemel Hempstead
    I'm with Stiggy on this and a periodic rebuild cannot be beat.
  20. stricko
    stricko
    Jan 20, 2004
    293
    Lambourn
    +6
    Take the Stiggy approach, but use something like TrueImage or Ghost to take a snap shot of your "clean" system immediately after the rebuild, including as much as your "standard" software (and 100 million add-ons :) ) as necessary. A "clean" re-build then only takes an hour or so, re-apply any changes, redo the snap shot, and away you go. I manage 4 PCs this way, and it's worked a treat. Never really tried a registry cleaner.
  21. sunnybacon
    sunnybacon
    Mar 6, 2008
    3,267
    Leicester
    +433
    CCleaner. Given no problemos.
  22. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    at least 3 pcs a week come to my pc repair shop wich need to be reinstalled due to the likes of registry cleaning programs etc .
    we always advise leave well alone i know every one has a different view on these programs .this is just our findings week in week out.:thumbsup:
  23. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,579
    +6,591
    It is the windows registry entries that some cleaners are a bit too eager to please, that you need to be careful with
    If you want to see an easy example, install regscrubxp, then try and start msn ;)
