D
Daemonia
I was just wondering what is the best setting for recording. Obviously, for HDD playback, I use XP. But what about stuff I intend to burn later to DVD-R? Should I record in XP and then record to disc using FR (flexible record) or record in SP?
I ask this because in experiments, when I recorded in SP and burned to DVD using high-speed record, it used up less disc space and had a lower bit-rate than when I recorded in XP and then, essentially, re-encoded it in SP for DVD-R, if you get my meaning. This used up almost all the disc space and had a higher bit-rate. But am I really losing anything by using SD>SD, rather than XP>SP?
Does anyone know what I mean and can you offer advice on this?
