Best receiver for under £400
Discussion in 'AV Receivers & Amplifiers' started by Simon55, Apr 14, 2002.
  1. Simon55
    Simon55
    as title really, it must have the following:
    • At least 50WPC
    • Ability to decode DD+DTS, DPL, DPL2 pref 6.1 channels
    • S-video switching
    • front AV inputs
    • Remote control
    I know some of the above are pretty standard but they are basic things i must have, i havent bought a receiver in yonks and yonks and am out of touch with current models,
  2. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Some of the models currently on the market that would fit the bill would be:
    Marantz SR5200
    or alternatively one of the new Yamaha's such as:
    Yamaha DSPAX630
    There's not many at the sub £400 mark with all the features you're looking for. These two are probably worth an audition.
  3. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    The best Amp for under £400 is whichever Amp sounds "best" to you. No one can tell you which is the best. It's imperative to audition them yourself. Create a shortlist of the ones that match the features you're looking for and then demo them with CD/DVD's that you are familiar with. The Marantz sr5200 fulfills you list of wants at your pricepoint but really do try and listen to it before comitting. :)
  4. Simon55
    Simon55
    Cheers for that :) i was reading what hifi at work today and the SR5200 got a really really good review, they had it against some others and it won by miles.
    Seen it for £330 as well so that would be great, i have an SR3000 now which i love to bits, just want onboard decoding and DPL2 really, along with a touch more power, i trust the SR5200 will sound similar to the SR3000 in stereo as this will be used for music as well thru some Kef 105/2 speakers.
    One thing ive spotted, whats the difference between the SR5200-E and the SR5200? as the SR5200-E is £50 less
