Best "reasonable" DVD for Panasonic Plasma PH9
Discussion in 'Blu-ray & DVD Players & Recorders' started by starre, May 1, 2007.
  1. starre
    starre
    Nov 5, 2006
    141
    +4
    just got a 42" panasonic plasma pH9. had my heart set on getting an OPPO 981 DVD player but after doing a few searches, i found on AVSFORUM that some were saying the combination of:
    OPPO+Panasonic plasma = macroblocking
    so maybe the OPPO for me isn't worth the $230 + $60 shipping.
    would any of you have any suggestions for a decent progressive DVD player (Pioneer 490S for example?) with HDMI (my component is taken up by the cable box) for my PH9 to hold me over until HD DVD/Bluray is more economical?
    many thanx!!!
  2. Lufer
    Lufer
    Feb 22, 2006
    134
    +12
    I was in a similar situation. Not wanting to splash too much on a dvd that will last until the HD waters are somewhat more clear. I picked up a Sony NS76 DVD from John lewis, ex-display for £79. Great bit of kit for that money!
  3. tricky1974
    tricky1974
    Panny s52 great wee dvd player easy to region free,I've a Marantz DV7600 and at standard def into my pv500 plasma theres not much in it (picture wise)between the two, so i use the s52 and use the marantz with my lcd in the games room. and once the hacked firmware's in the s52 the (just zoom)fuction can fix overscan :smashin:
  4. starre
    starre
    Nov 5, 2006
    141
    +4
    thanks - i'll check out the two players! anybody else with a good fit for a PH9 plasma?
  5. MIB
    MIB
    Apr 29, 2005
    2,122
    +108
    I run a Denon 2900 with a PH8 - cracking picture via component.
    They are build like a tank and originally cost about £900 new but you should be able to pick one up in the classifieds for about £200
  6. MIB
    MIB
    Apr 29, 2005
    2,122
    +108
    sorry just read you want HDMI so ignore the 2900
