Best rear centre speakers for Mission m72 package
Discussion in 'AV Receivers & Amplifiers' started by Dr.Rock, Feb 26, 2002.
  1. Dr.Rock
    Dr.Rock
    Jan 10, 2002
    684
    London, UK.
    +34
    What are recommended type of speakers to use as rear centre, to go with Mission's M72 package?
    One shop recommended using a duplicate speaker to my front-centre. Another recommended I use the same as the dipole surround speakers. Another suggested shelf speakers.
    Thanks.
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    I'd try to keep the speaker one from the same manufacturer as the rest of your speakers, or at least your fronts. Duplicate centre would probably be the wisest choice, or another rear would be fine but you'd have to buy a pair.
