Best RC Software for PPC
Discussion in 'Home Cinema Control & Remote Controls' started by AVFan7667, Dec 22, 2004.
  1. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    Can anyone recommend the best RC software for my PPC (Dell Axim X5).
    Also, I believe the X5 has a pretty poor IR range, so can anyone recommend a good CF IR extender?
    Any URLs to the relevant products would be much appreciated.
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Have you seen TV Remote controller from PDAWIN: www.pdawin.com. Allows you to use Pronto CCF's.
    I use it with an iPAQ 2210 to control my gear.
    John
  3. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    Yes, downloaded a trial now. Seems really good.
    Need to find a CF IR range extender that will work with it now though as the IR range on my X5 is pretty poor.
  4. dalepearson
    dalepearson
    Aug 27, 2004
    181
    +11
    How do you guys find using these as remotes? Do u have the program set to run as soon as your turn it on or something?
  5. raydundas@bluey
    raydundas@bluey
    If you need an extender and software, then ultramote is the obvious choice at www.ultramote.com. Not very expensive either
  6. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    The software that comes with Ultramote is rubbish from what I can tell. I have been told by a few sources now that the Ultramote extender works well with PDAWin's TW Remote Controller, so I think I will buy it to go with that as it seems much better software.
    I'd like to hear from anyone who has the Ultramote Extentder though as I'd like to know what sort of range and radius it has. Does it have to be pointing directly at the device or can it just be vaguely in that direction?
  7. raydundas@bluey
    raydundas@bluey
    Fair enough, but you will need to buy the software anyway. I tried to buy the extender without the software. I even had a legit 16 digit code from a PDA, but because they had no record of me buying the software, the order was refused the day after I ordered it, so had to order both
  8. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    How directional would you say it is?
  9. raydundas@bluey
    raydundas@bluey
    Will let you know when it arrives in a couple of days
  10. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,118
    Southampton
    +262
    Order a PDAir from www.laser.com - although there may be only a few left now at best - and the PPC version of Remote Control II from www.wincesoft.de
    You won't go far wrong with the above.
  11. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    On the iPAQ, it doesn't close programs down when you switch it off so, if I've been using TV Remote, I just switch the iPAQ off and, next time I switch it on, TV Remote is already running - makes it nice and easy to use, particularly for my wife.
    John
