Best RC software for iPaq 5400 series ??
Discussion in 'Home Cinema Control & Remote Controls' started by JohnCCFC, Apr 26, 2005.
  1. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    Sorry if it's an obvious question. Haven't searched, bit busy. If anyone has ideas I'm keen to use my redundant HP iPaq 5400 series as a remote and have struggled through some poor (seeming) freeware and wondered if there's a good choice anyone can recommend.
    Thanks.
  2. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,001
    Southampton
    +233
    Try Remote Control II from WinCEsoft - there is a trial version
    freely downloadable here to help you make your mind up.
  3. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    Have you tired TV Remote Controller from www.pdawin.com - works with Phillips Pronto CCF's as well.
    John
  4. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    Thanks for the replys guys. I (ROM flash) updated my iPaq to use Windows Mobile 2003, would these both work on this OS?
  5. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    I've got TV Remote Controller working under 2003 on my iPaq 2210.
    John
  6. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    Thanks mate, I shall give it a go.
  7. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    johndon,
    Wonder if I can grill you a little further.
    I have the s/w and I've downloaded the CCFs for (most of) my devices.
    Problem is, I can't seem to use one CCF after another without a fiddly pen clicking and ccf file selecting exercise.
    Is there any way to bring them all in, the way they would be if I simply selected from pre-determined devices built in?
    Sorry, I appreciate that you're not TV Rem support helpdesk. BUt I like what I see so long as this is do-able.
  8. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    There's no way that you can bring them in to run as one AFAIK.
    I downloaded a copy of Pronto Edit (which, despite some bad reports, I found vrey easy to use) and then used that to create a single CCF to control all of my devices.
    John
