Best quality for viewing dvd HDMI or component
Discussion in 'Blu-ray & DVD Players & Recorders' started by Chadd, Jan 10, 2005.
  1. Chadd
    Chadd
    Ok which gives the best quality from a dvd? HDMI or Component connections? i have had conflicting responses to this as soem sources says HDMI is best suited for hidef television broadcasts.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    HDMI, no question .. if all else is equal then passing the video in digital form from DVD to display has to be better than doing D->A and A->D conversions, except perhaps with top-end equipment with very expensive DACs and even then I don't see how the HDMI path could be inferior.
    That comment about HDMI being 'best suited for hidef' is, IMHO, meaningless :), that fact that it is 'best' for hidef (even if I accepted that, which I don't), has no bearing on its' ability to carry SD material.
    It could be interesting to see the context in which you saw that comment.
