Best Quality Connections for CRT
Discussion in 'Desktop & Laptop Computers Forum' started by jameson_uk, Jun 27, 2005.
  1. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    I have an oldish CRT TV, a telewest digital cable STB and my HTPC (complete with PVR150 card).
    Currently I have a cheap converter RGB to S-Video converter from Maplins to take the RGB scart out of the STB and into the PVR card. I can not get the RGB scart option on my Radeon 9200 to work (just can not get the signal to sync) so I am using the S-Video out.
    This means I am getting RGB out from STB, degrading the signal, sticking it into PC (and degrading signal) and then outputing on a fairly poor TV-Out.
    Surely there must be a better way of doing this ?? The sweetspot looks good but I really want to keep hardware encoding of the PVR150 and can't see any way of doing this with the sweetspot.
    X-card looks good for output but as it only outputs MPEG streams it is a bit useless as I won't be able to see the GUI. (I did try that software which outputs gui onto x-card but I did not like it)
    How do others connect STB to HTPC and what other options do I have ??
  2. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    No takers ??
    I am sure someone must have a STB connected to their HTPC :D
