Best PS to PC Adapter?
Discussion in 'PC Gaming & Rigs' started by PGL, Dec 15, 2003.
  1. PGL
    PGL
    Anyone know which is the best Playstation controller to PC adapter to enable me to play PC games on my PC using a Playstation controller instead of mouse/keys? Have looked at some on Play.com (currently out of stock) and www.lik-sang.com but there seems to be a lot of different ones. Any ideas folks?
  2. Sinzer
    Sinzer
    May 25, 2002
    5,793
    +1,108
    I got mine from consoleplus about a tenner works fine. Sorry don't have the link to hand, can post it later (Search on google meister for consoleplus!)
  3. PGL
    PGL
    Cheers for that. Can you remember which model it was?
  4. Solar
    Solar
    Dec 2, 2003
    2,541
    Earth
    +477
  5. Sinzer
    Sinzer
    May 25, 2002
    5,793
    +1,108
  6. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    The one on play.com is back in stock, it seems.
  7. kron
    kron
    Feb 24, 2003
    1,262
    Plymouth
    +135
    I can also recommend the Boom PS/N64 adapter, got it from http://www.kwiktoys.com , £12 excluding ,handy being able to use Nochex to pay as well
    it's replaced the one i got from Play.com which i couldn't get to work with NFSU
  8. Erpland
    Erpland
    I also recommend the Boom PS/N64, got two from Lik-Sang,
    tried it with a Playstation wheel and N64 controller, both work great.
  9. kron
    kron
    Feb 24, 2003
    1,262
    Plymouth
    +135
    There is a fix now for the Play.com converter, if like me you installed the drivers that come with it on the disc the pad won't work with NFSU ,short of reformatting the answer is as follows:
    Go to Start>Run>regedit
    Once there navigate to....
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contr
    ol\MediaProperties\PrivateProperties\Joystick\OEM\
    VID_0B43&PID_0003
    Click on the + next to the 'VID_0B43&PID_0003' folder and you will see a folder called 'Axes'. Delete the Axes folder and the pad will now work in NFSU
    Found it on another forum, fudges up the vibration tho i think.
