Best projector for approx £600?
Discussion in 'Projectors, Screens & Video Processors' started by Onus, Dec 5, 2004.
  1. Onus
    Onus
    Dec 5, 2004
    28
    Hi everyone,
    i'm new to the forums and i've decided to get my first projector!
    It will be going in my bedroom and i will be using it for games (xbox), and dvds.
    the only one i've really found with good reviews is the Epson TW10H.
    Are there any others i should consider in this price range?
    Also would you recommend waiting 'till after christmas...Is it likely there will be a significant drop in the price of projectors?
    many thanks
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Hi :hiya:
    Fankly for that money I think the Epson is the only one worth looking at, unless there's one I've missed everything else up to that price will be designed for data presentation use rather than watching DVDs.
    A price drop after Christmas would be unlikely I think, new models are released at this time of year, starting September or so, which means last year's models have been discounted while thins year's are now brand new, so unless a retailer needs to drum up business I don't think we'll see markedly cheaper prices come January.
  3. Onus
    Onus
    Dec 5, 2004
    28
    Hi :hiya:
    :) thanks for the reply.....yeah it doesn't look like theres anything else worth looking at apart from the epson.
    I'm probably gonna get it from dabs or technoworld.
    cheers
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I'd check that it's not available at a dedicated Home Cinema e-tailer round here for a similar price, if you have problems it's usually better to be dealing with someone who specialises in this type of equipment .. and some can be as cheap as places like Dabs in my experience.
  5. Onus
    Onus
    Dec 5, 2004
    28
    good idea, i'll have a look thanks.
  6. commie
    commie
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I was trying not to show favouritism. ;)
  9. Onus
    Onus
    Dec 5, 2004
    28
    will i be too close to the picture if i only sit 2.7 metres away from the screen? will i see lines in the picture nad stuff?
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    how far away will PJ be? how big will the image be, you can tune image using the zoom lens but go get a demo
  11. Onus
    Onus
    Dec 5, 2004
    28
    projector will be 2.4 mtres away from the screen and i will be sitting 2.7 metres away from the screen. On the projection calculator it said it should be 79" diag. 69" horiz. and 39 vertically from 2 metres with the zoom to the max. I would have the zoom upto 1.2.
  12. imf
    imf
    You should be at least 3 feets behind the projector to not see any chicken wires, but if you do you can always defocus image little bit. I have TW10H and with 80" image and sitting just 4 or 5 feets behind the PJ it´s just fine, no chicken wire or screendoor visible.
  13. starfire
    starfire
    Jun 15, 2004
    366
    +25
    I got an Infocus X1 from ebuyer which is excellent.
    They are out of stock of this now but do have an X1a at £500 - if you drive this with a progressive signal its identical to an X1.
    Checkout avsforum.com for more details on the X1.
  14. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    The X1 is fine as long as one isn't susceptible to rainbows, it's a DLP with a slow 2x colour wheel so more people will be affected by this model than one of the newer 4x or 5x machines.
  15. patt
    patt
    Nov 18, 2004
    394
    huntingdon
    +10
  16. monopole
    monopole
  17. ismangil
    ismangil
    Nov 30, 2004
    65
    Sheffield
    Pixmania still has the original X1 not X1a for £598 delivered, if you use the £10 voucher off "priceuk070" or something I got from Pricerunner. I also looked at the Epson but then decided to for DLP. So far I and my wife haven't seen any rainbows...
  18. Onus
    Onus
    Dec 5, 2004
    28
    many thanks for the replys people, i will take it all into consideration.
    cheers
  19. LouisB
    LouisB
    Having recently bought one (a TW10H), I find it hard to imagine that you would be even slightly dissapointed with the TW10H, especially for the price,
    No rainbows,
    RGB input! for added flexibility (sky box, games console...) as well as all the other usual inputs (component, VGA, Composite, S-Video)
    Native widescreen
    Theatre black mode
    Quiet
    Easy to set up
    Cheap lamps!
    what else can I say, what are you waiting for?
    cheers,
    Louis
  20. noel-pilot
    noel-pilot
    Dec 20, 2004
    having done a bit of research and reading many great posts on this forum (arent forums great!!!) I think im heading towards an epson, guess my only initial reason for not considering it was maybe a little mistaken brand snobbery!!
    now its time to find somewhere around north london that will give me a demo of it just to make sure i like it!!
    From the above im assuming there is now else worth considering in the same price range>?!!
    additional question, how much worse is the picture likely to be, if i project directly onto a smooth painted wall (either white or very light cream i think) Will be getting a screen eventually but will the wall suffice initially? thank you all.
