Best Progressive Pal DVD Arcam 88+?
Discussion in 'Blu-ray & DVD Players & Recorders' started by FCP FAN, Jun 20, 2003.
Tags:
  1. FCP FAN
    FCP FAN
    Cheers!:)
    I need your advice on this:
    I need a Pal Progressive Scan player: What should i do:
    Please consider::confused:
    1) I have an Arcam DV88 and i can upgrade to DV88P but its £450;
    2) there are a lot of great players coming out(eg. Sony 999ES );
    3) Currently i use my Arcam as a CD source also, so if i switch it
    for other player it should be as good in audio;
    3) If I upgrade the Arcam it would be a £1500 player -is it worth it?
    Since the DV88+ was the first player boasting Pal Progressive all the reviews on this player that i find doesnt seem to consider other options...
    Please give you opinion.
    Thanks!
  2. FCP FAN
    FCP FAN
    Is anybody out there?:confused:
  3. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Well if your thinking of the Pioneer 757Ai (pal prog allegedly out soon) I can tell you it's a cracking DVD player, but absolutely dire as a CD player, not a patch on my 400 quid rega planet.
  4. StooMonster
    StooMonster
    Nov 20, 2002
    4,971
    Kent
    +314
    Arcam DV88P and AV88 Plus (often called DV88+) are two different players. DV88P is a DV88 with a Silicon Image progressive scan board, and is therefore similar to original DV27. DV88+ and DV27+ and DV89 use a different chipset. Upgrading a DV88 to a DV89 is the biggest jump and most expensive (£650); but you should be able to upgrade your DV88 to either a DV88P (£350) or DV88+ (£400). All those players are PAL progressive compatible, except original DV88.
    StooMonster
  5. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Although you didn't specifically mention it as an option, what about introducing a standalone deinterlacer, something like the Iscan Ultra for example?
    These are currently available for around £550 from some retailers and it would mean you could make any of your other sources progressive scan as well.
    Just a thought.
  6. StooMonster
    StooMonster
    Nov 20, 2002
    4,971
    Kent
    +314
    That's a thought!
    I've had one of these since they first came out -- for doing exactly that with all my interlaced sources (eveything except DV27+). Results are excellent.
    I've even run the DV27 interlaced output though it, and it's not that much worse but has the chroma bug removed. (iScan Ultra has a chroma filter and will get rid of chroma bug from any DVD player.)
    StooMonster
  7. FCP FAN
    FCP FAN
    Thanks people for your opinions!:p
    Right now im considering just 2 solutions:
    1) Upgrade from DV88 to DV88P (since e dont care for DVD-A)
    (wy didn´t Arcam go with SACD?:( )
    2) Switching my DV88 for a new player that can handle cd replay
    with the same quality - I saw a Sony NVP-999ES (i think thats the right model) and altough it was gold (ouch) it looked kind of cool but i dont know how the CD replay from that player sound...
    Maybe i wait a couple of monthd for other options?
  8. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Just to add that if you were to pursue the offboard deinterlacer, then you could retain your current player, along with its CD playback abilities that you like.
    A bit like having your cake and eating it! :)
  9. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    FCP, unless you have a really big screen (40-inch plus) you may not find prog scan worth the money. A lot of people on here do have such screens and therefore look on it as a necessity, but I have a 32-inch plasma and to be honest don't see an awful lot of difference. I suggest you get some demos before you dig into your pocket.
