Best pro scan dvd player
Discussion in 'Blu-ray & DVD Players & Recorders' started by grayson, May 23, 2004.
  1. grayson
    grayson
    Which is the best Pro scan dvd player, I have a budget of £300 I need pal and ntsc pro scan I dont need dvd audio. At the minute I have the yamaha s540 pro scan player, will there be much of a difference in picture quality if i upgrade. also is the new pannyDMRE55EBS worth considering its a dvd recorder with pro scan. Many Thanks
  2. chris
    chris
    Nov 20, 2000
    1,232
    romney marsh, kent, uk
    +30
    Whats wrong with what you have now, that you feel the need to upgrade......????
  3. grayson
    grayson
    I connected my pc to my plasma via dvi and it puts the yamaha to shame very sharp picure, the only thing is the noise of the pc is very irritating during quiet scenes, so i want a player that comes close to the pc dvi performance without the noise. I have a panny 6 and I hear there are some issues with a standalone dvi dvd player
