the panasonics and the toshiba i think are the best you will pick both up for the price you stated
try www.nexnix.co.uk www.tmfsolutions.co.uk
both have good reviews by people
you wont need a tuner if you have sky but you will need a lead to convert it from rgb to vga or component try www.rgbtosvideo.com
hope this helps
Thanks Jmack - I see you can have a BNC board fitted - would this be a better connection?
Panasonic TH-42PWD4BX
NEW low Price:
VGA only - £3,500.00 (incl. vat)
With BNC video board - £3,504.62 (incl. vat)
&BNCUPGRADE
I've just got the TH42-PWD4BX for £3100 including VAT and delivery from Sound and Vision in Bolton. I also got buy now pay in 12 months.
Absolutely brilliant picture, money well spent.
Ask for George.
the boards have been changed now from bnc to straight coponent in for the uk market there are still some around (normally older models but that is the only diffrence .You can buy an adaptor for £2 from maplin anyway so they tend to be good buys.
