Best price for Mission Cinema 72?
Discussion in 'Home Cinema Speakers' started by daveyp, Jan 6, 2003.
  1. daveyp
    daveyp
    Not sure if this is the right forum to ask this, but...
    I'm looking for the best price on the Mission Cinema 72 package. I'm sure I read one post a week or so ago that said they'd found it for £199 (what a bargain!), but I can't find the thread now :(
    The best price I've found so far is around £265 at www.qed-uk.com
    I was surprised that the Richer Sounds web site is listing it for £399 (which is the actual Mission RRP) and are calling it a "scoop" :eek:
    Many many thanks in advance!
  2. smallman28
    smallman28
    Mission recently urgraded the 70 series of speakers.
    The newer versions are called M70i,M71i etc.
    They are basically the same except for more internal bracing.
    So the cheaper prices for the 72 package maybe as a result of this and use the "older" speakers and the RS price is maybe for the "newer" versions.
    If you can get a set that uses the older ones for cheap enough it maybe worth going for,the prices across the M70 range dropped quite dramatically before the arrival of the newer versions.
  3. daveyp
    daveyp
    Cheers for that!
    I did wonder why some places referred to the "Cinema 72" and others to the "Cinema m72" - I had assumed that they were two different names for the same thing.
