Best price for an 8ft 16:9 Projector screen
Discussion in 'Projectors, Screens & Video Processors' started by keelby1, Jun 13, 2003.
  1. keelby1
    keelby1
    Dec 11, 2002
    1,182
    38
    Grimsby
    +12
    I'm after an 8ft Manual 16:9 projector screen for a Panny ae100. It needs to be concealed as neatly as possible behind 4-5" exposed beams.
    Could anyone recomend one and also where to buy at a reasonable price
  2. Kramer
    Kramer
    Projecta Proscreen would be my recommendation - reasonably priced & good quality.
    Extra large black drop included for the price too for optimum viewing height.
    Up the ladder - an Owl electric screen would be nice - one of the best but @ £1000, not cheap.
    Suppliers? Loads around, try a quick search here/google.
    :smoke:
  3. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Probably a little less expensive than the procinema line, but might do the trick.........try Komplett here
    Sean G.
  4. pinkerton
    pinkerton
    Sep 26, 2002
    416
    Ealing (London)
    +3
    blackout material from john lewis =£12
    wood supplied for free + hours of work got me a nice 8 foot widescreen display.
    Worth considering.
  5. Captain chaos
    Captain chaos
    You can have an 8ft white / grey pull down blind made for about £80 - 100. Try local homeware retailers like Habitat or Ikea.
