Best powerstrip setting for Sony VPL-HS2
Discussion in 'Projectors, Screens & Video Processors' started by cheetahman, Oct 11, 2003.
  1. cheetahman
    cheetahman
    I am looking for help on configuring my pj for the best quality. My current configuration is as follows.
    Soy VPL-HS2
    Da-Lite 120" Diag 16x9 Hi-Contrast
    PJ multi-connector -> SVGA + mini
    HTPC with Radeon 8500
    Powerstrip 3.45 configured @ 1366x768 @56hz
    Any help is appreciated.
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    The only thing missing from that setup is some form of calibration. You could try DVD Essentials calibration disk. It comes with several filters etc to enable you to set up your system for optimum results although you might find you chasing a ever diminishing return on your time.
    Otherwise.
    EDIT: Whoops... Didn't read the question properly. I'll look into it.
    I thought the specs of you machine where (see below), surely the best powerstrip setting would be to set a custom resolution of 858 x 484 @ 60Hz!
    Specifications for the VPLHS2 LCD Projector
    Liquid crystal panel Wide 16:9 panel 3x 0.62" poly silicon LCD
    Resolution 1.2 megapixel (858×484 pixels)
    Lamp 150W UHP
    Contrast Ratio 600:1
    Brightness 850 ANSI lumens (Cinema black off)
    Inputs 1 x Composite, 1 x S-Video, 1 x RGB/Component
    Colour System NTSC3.58 / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N automatic / manual change
    Noise 30dB
    Electrical power consumption 200W (Standby 3w)
    External size Width 304mm
    Height 168mm
    Depth 321mm
    Weight Approximately 4.5kg
