Best Possible Picture quality
Discussion in 'Projectors, Screens & Video Processors' started by DEO, May 7, 2003.
  1. DEO
    DEO
    I would like the best possible PQ so excuse me if I am missing something obvious:
    If one decides to use a good quality scalar (ie Lumagen) in conjunction with a Plasma why is there a need to spend £1K or £2K + on a pal/ntsc progressive DVD player?
    After all the scalar will improve the sky/freeview PQ as well.
    Furthermore a DVD player can only de-interlace and cannot scale therefore cannot generate a PQ that is comparable to the scalar.
    Dave
  2. DEO
    DEO
    I guess the difference is the sound quality and sound quality alone?
  3. lmccauley
    lmccauley
    Oct 24, 2000
    3,295
    Newcastle
    +212
    You are correct that there is little point paying for the Progressive Scan facility in a DVD player when your scaler will do that for you. However, de-interlacing isn't the only thing that makes up a good quality DVD output.
    Cheers,
    Liam
  4. DEO
    DEO
    Thanks Liam, what ar the other things then, is it the sound?
  5. EvilMudge
    EvilMudge
    Quality of the MPEG decoder and it's ability to do block noise reduction, motion interpolation and a whole host of other things that scalers/deinterlacers can't do is important. Have a look at the interlaced output from a TAG DVD for example with a low bitrate disc, compared to say the interlaced output from a high end Toshiba - given a good enough display there are visible differences.
