Typical Janner
I'm currently looking for a new MP3 player, and the main criteria is that it must be accessible to somebody with low vision.
In real terms, this means that there must be some possibility of reading what is on the screen. This is likely to rule out all the players which only have a small grayscale LCD screen. It would also be preferable for the display to have light text on a dark background (do any players allow for customisation of the display settings?).
Would prefer a device that allows you to simply drag and drop files via Windows Explorer (there might be accessiblity issues with some of the proprietary software that some players require you to use).
Probably looking for 20GB or more. Budget is about £200, although this could be stretch if necessary.
