Best player for £50 or under
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jack Ryan, Jun 20, 2005.
  1. Jack Ryan
    Jack Ryan
    Apr 9, 2002
    37
    Basingstoke, Hampshire
    Been scouring the forum for advice. DVD player (mulit region of course) needed for bedroom to link to very impressive little Mikomi 17".
    Options seem to be:
    Alba - DVD65, supermarkets and web £29.99
    Philips DVP520, or its replacement DVP3005/05, £49.99 Tesco, Argos.
    Limit DVD800SE, in stock at Play.com for £44.99
    Limit DVDA900SE, again at Play.com for £49.99
    or a touch over budget:
    Sony DVPNS30, Amazon for £56.90
    Philips DVP630, or replacement DVP5100 £79.99 (not sure worth the extra)
    Are there any others I should be thinking of?
    And is there really any contest? I get the feeling the Limit option is the one but, if so, should I go old or new?
    Thanks in advance.
  2. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,434
    Try a Yamada 6700 for good divx/xvid compatiblity. :) £45
  3. chachi
    chachi
    Is audio playback a consideration at all? If so the Limit 900 model that Cyrus has tweaked will run rings around everything you've listed for audio playback CD wise and also supports DVD-A which is quite nice to have if exploitable ...
  4. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    I've ordered the limit 900 for my gf has it seems to play everything I would chuck at it!
  5. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    try tosh sd140 =30 form ritcher sounds or 150 for arround 40 pounds
    Azz
