Best plasma
Discussion in 'Plasma TVs' started by 5timeswinners, Sep 14, 2005.
  1. 5timeswinners
    5timeswinners
    Aug 30, 2005
    16
    Southport
    Hi all
    Need some advice on buying a plasma. I would like a 42 inch HDMI plasma but cannot afford the panasonic. Which is the best one after that for around £2000.
  2. tscotsman
    tscotsman
    Dec 29, 2004
    846
    +15
    Probably Hitachi 7200 or Samsung
  3. Will35
    Will35
    Aug 31, 2005
    47
    Somewhere on the M50....
    Try looking at the Pioneer PDP43FDE from Richer Sounds - £2,200. I recently got one and it includes stand, speakers & media box. Has HDMI connection and pictures are very good with Sky+...
    Will
  4. bishman
    bishman
    Mar 29, 2001
    4,902
    83
    hertford
    +172
    I chose the Hitachi 42pd7200 above the Panasonic even though I could afford either. I had demos and couldn't see that there was enough of a difference to warrant the increased spend required for the Panasonic. For regular TV the Panasonic had a slight edge but as I don't watch much TV it wasn't a factor for me. With DVD there was very little to choose between them. Got mine on Monday and I am delighted with it and TV is actually better than I expected with my NTL digital.
    [​IMG]
  5. bluecupra
    bluecupra
    That picture looks really good. I think the motion blur has something to do with the photo rather then the screen? The colours look really good
    Jeffrey
  6. shadybrady
    shadybrady
    Sep 1, 2005
    152
    Isle of Man
    +20
    You can get the panasonic for about £2000, check out discounttv.co.uk or unbeatable who have it down as £2,200 this is for the 42 version with pedestal.
