Best plasma right now?
Discussion in 'Plasma TVs Forum' started by davsdu, Feb 13, 2005.
  1. davsdu
    davsdu
    Feb 13, 2005
    183
    +3
    What model is considered the best 42" plasma display right now? Im thinking in terms of overall picture quality from dvd and digital television.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,110
    DAVSDU: The reality is that it depends on a whole load of things which is best for you. The end result is you need to go look at some. When you do go to view try to see the things set up as they would be if you bought them and view from the distance you would likely sit. Some artefacts are objectionable from a fair distance while others you might not notice at more than 10ft from a 42" screen....Of course finding units set up at their best isn't that easy....
    Gordon
  4. Ymegod
    Ymegod
    Nov 14, 2004
    175
    Bromley, Kent
    Nice one Gordon. Succinctly put and not a single plug in sight.
