kellyleekyle
Established Member
hi, comet are making the final decision tomorrow if their going to replace my samsung ps50p96fd plasma. Ive had it 18 months and is covered by D&G extended warranty. If they decide to replace it, what do you guys think i should accept as a replacement, they no longer make the origional model, the new samsungs seem to be a much lower spec, the one i bought was top of the range, their first full hd, cost £1,600, seems they took some of the spec out to make them cheaper. this is the spec of my sammy. i dont want to settle for less than i already have,thanks
Features
50" Widescreen Plasma TV
1000cd/m2 Brightness
15,000:1 Contrast Ratio
1920x1080 Screen Resolution
Full 1080p HD Ready
DNIe Engine Technology
Anti Burn-in Technology
SRS TruSurround XT
Digital Progressive Scan
175/175 degrees viewing angle
Teletext 2.5
Remote Control
2 x 15Watt Integrated Stereo Speakers
Connections
3 x HDMI 1.3
1 x RF
2 x Scart Connection
1 x Component In
1 x PC/VGA In
1 x Optical Digital Audio
1 x Headphones Connection
tech spec
General
Product Type 50" plasma TV
Digital Television Certification HD ready 1080p
TV Tuner 1x analogue, 1x digital
Video Interface Component, composite, HDMI, S-Video, SCART
PC Interface VGA (HD-15)
HDCP Compatible Yes
Dimensions With stand
Width 129 cm
Depth 32 cm
Height 80.4 cm
Weight 48.5 kg
Enclosure Colour Black
Display
Diagonal Size 50" - widescreen
Technology Plasma (PDP)
Resolution 1920 x 1080
Display Format 1080p (FullHD)
Image Aspect Ratio 16:9
Colour Depth Up to 68.7 billion colours
Dynamic Contrast Ratio 10000:1
Brightness 1000 cd/m2
Progressive Scan Progressive scanning (line doubling)
Widescreen Modes Conventional 4:3, Auto Wide, Wide Zoom, 16:9, Just
Viewing Angle 175 degrees
Viewing Angle (Vertical) 175 degrees
Backlight Life 60,000 hour(s)
Comb Filter 3D digital
Colour Temperature Control Yes (Warm1/Warm2/Normal/Cool1/Cool2)
Picture Adjustment Standard/Dynamic/Film/Custom
Features Video noise reduction, Auto Power Off, parental control, on-screen menu, DNIe (Digital Natural Image engine), FilterBright, game mode
DVD
Features Anynet+
TV Tuner
Analogue TV Tuner PAL, SECAM
Multi-channel Preview Picture-in-picture (PIP) (1 tuner)
Reception System SECAM-D, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, SECAM-L, PAL-K
Stereo Reception System NICAM, A2
Digital TV Tuner
Digital TV Tuner DVB-T
Video Features
HD Ready Yes
Analogue Video Input Signals PAL, SECAM, NTSC4.43
Input Video Formats 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Supported Computer Resolutions 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 640 x 350, 720 x 400, 1920 x 1080
Teletext Yes
Teletext Memory 1000 pages
Parental Channel Lock Yes
NTSC Playback on PAL TV Yes
Remote Control
Type Universal remote control - infrared
Remote Control Model Samsung TM87C
Supported Devices VCR, sattelite TV system, cable box, DVD player
Audio System
Sound Output Mode Stereo
Surround Mode Built-in
Sound Effects SRS TruSurround XT
Audio Controls Sound mode, equalizer, balance
Equaliser Yes (5-band)
Speakers Included 2 speakers
Output Power / Total 30 Watt
Features Auto volume adjustment, balance control
Speaker(s) 2 x right/left channel speaker - built-in - 15 Watt
Connections
Connector Type 1 x S-Video input ( 4 PIN mini-DIN ) - side ¦ 1 x composite video/audio input ( RCA phono x 3 ) - side ¦ 1 x headphones ( mini-phone stereo 3.5 mm ) - side ¦ 2 x SCART ( 21 PIN SCART ) - rear ¦ 2 x HDMI ( 19 pin HDMI Type A ) - rear ¦ 1 x component video input ( RCA phono x 3 ) - rear ¦ 2 x audio line-in ( RCA phono x 2 ) - rear ¦ 1 x audio line-out ( RCA phono x 2 ) - rear ¦ 1 x VGA input ( 15 PIN HD D-Sub (HD-15) ) - rear ¦ 1 x audio line-in ( mini-phone stereo 3.5 mm ) - rear ¦ 1 x digital audio output (optical) ( TOS Link ) - rear ¦ 1 x HDMI ( 21 PIN SCART ) - side
Slot Provided Common Interface slot
Stands & Mounts
Stand Included Built-in
Stand Design Tabletop
Stand Features Swivel
Flat Panel Mount Interface 600 x 400 mm
Power
Power Device Power supply - internal
Voltage Required AC 230V ( 50/60 Hz )
Power Consumption Stand by / Sleep 1 Watt
Power Consumption Operational 520 watt
Features
Full 1080p HD Ready
SRS TruSurround XT
Teletext 2.5
Remote Control
Connections
3 x HDMI 1.3
1 x RF
1 x Component In
1 x PC/VGA In
tech spec
General
HDCP Compatible Yes
Width 129 cm
Depth 32 cm
Height 80.4 cm
Weight 48.5 kg
Display
DVD
Features Anynet+
TV Tuner
Digital TV Tuner
Video Features
HD Ready Yes
Teletext Yes
Remote Control
Audio System
Connections
Stands & Mounts
Power
