Best plasma for under 5K?
Discussion in 'Plasma TVs' started by (GTV)Chris, Jan 1, 2003.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    I am a lcd projector person but my friend would like a plasma 42" and wants to spend upto 5K on it.
    What would you recommend he looks at?
    Many thanks
    Chris
  2. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    I went for the Pioneer 433 MXE which you can get for about £3500, I thought it was the best of the bunch , but lots of guys on here have gone for the Panasonic , these two seem to be the best .
  3. andybryant
    andybryant
    Dec 30, 2002
    9
    Bishop's Stortford
    I saw the PDP-433HDE in a few shops at the weekend, and wasn't impressed by its black levels. The shop assistant suggested that it was probably the setup, and nothing inherent in the display itself.
    How do you find the blacks on the PDP-433?
    Is the difference is between the PDP-433HDE, and the PDP-433MXE that the HDE includes the tuner box, and that the MXE is just the panel?
    Cheers, Andy.
