Best Plasma for under £1300
H
hardhousehead
Im looking for a plasma screen which can display 1080i signals and is under £1300. Im currently looking at the Samsung PS42Q7.
Is this a good choice or is there another plasma which is better for around my budget?
stainway
H
hardhousehead
is the sammy not good then cause I have read that it is nearly as good as the pioneer sets?
oasismark
I've been looking at the Samsung PS42Q7, although i didn't know it could display 1080 images?
Can you post links to what you have read about the Samsung PS42Q7.
hornydragon
Hold your horses here wha do you mean "display 1080i" ???? do you mean dsiplay 1080i with no scaling? Display 1080i signals? Or do you mean get a good picture from 1080i sources
stainway
Can't speak about the Sammy as I don't own one, but have a look here:
http://www.avforums.com/forums/showthread.php?t=338433&page=51
And some reviews about the LG can be found here:
http://www.unbeatable.co.uk/p_repr/L.../32602910.html
http://www.cnet.co.uk/misc/print/0,39030763,49279509,00.htm
Anyway you should also try to compare them side by side and see what you like more:hiya:
hornydragon
upscaling DVD players are a waste of money (the panel scales anyway) and 99% of cases does a better job
H
hardhousehead
Ok then what DVD player should I get for around £60 as my current surround sound system/dvd player dont have component out. Also I will need a dvd player that I can hook me surround sound system up to?
stainway
hardhousehead said:
Can the LG display 1080i from a samsung hd860 upscaling player via component ...
Yes LG 42PC1D can Display 1080i via component or HDMI.
hornydragon
well your surround sound will need the appropriate inputs £60 is naff all budget for a DVD player good ones start at £300 and go up to £1500 before you get into silly money :eek:
http://www.richersounds.com/showproduct.php?cda=showproduct&pid=TOSH-SD360-R2 is £60 no idea if its any good tho
H
hardhousehead
umm..yeh but I cant afford to spend £300 on a dvd player let alone over £1000 on the tv at the moment but Im strecthing as far as I can for the TV lol
H
hardhousehead
do u think I should get a Panny TH42PE50 or 42pwd8?
I have the option of those 2 pannys, the samsung or lg.
Can somone please tell me which one is best?
dickst3
If you have a tuner and sound I don't think you'll go far wrong with the 42PWD8 :smashin:
H
hardhousehead
I have an old cheap home cinema system which I dont think has component out so Il need to get a new one if I get a PWD8.
I have sky+, is that classed as a tuner?
dickst3
H
hardhousehead
do u guys really think the PW8 is better then the Hitachi PD9700 or Panny X60?
dickst3
My PWD7 makes me grin from ear to ear every time I switch it on - the PQ is amazing. I have just bought a 26" Sony LCD for the bedroom which pales in comparison...
Try a search, they are respected panels.
Similar threads
Trending threads
